Feature Control (HoloLens)
The File Encryption profile configuration enables you to use file encryption to secure the data stored on a device or a storage card. You perform this configuration when:
Secured data will only be readable on the device while encrypted.
Note: Feature control policies are only supported on HoloLens for Business devices.
Application
Auto Update of Store Applications | Select whether automatic updating of Windows Store apps is enabled, disabled, or configurable by the device user. |
Developer Model Unlock | Select whether developer unlock on devices is enabled, disabled, or configurable by the device user. |
Device Account
Enable Microsoft Account Connection | Select this option to enable device users to connect their devices to a Microsoft account. |
Search
Enable Search to Use Location | Select this option to enable Bing search to use the location services on the device. |
Enable Date Time Settings | Select this option to enable the device user to change date and time settings. |
Enable VPN Settings | Select this option to enable the device user to change VPN settings. |
Connectivity
Bluetooth
Enable Bluetooth | Select this option to enable Bluetooth usage on the device. |
Enable Bluetooth Discoverable Mode | Select this option to enable the Bluetooth discoverable mode. |
Set Bluetooth Device Name | Enter a string the specifies the local Bluetooth device name. |
Enable Bluetooth Advertising | Select this option to enable the device to act as a source for advertisements. |
Security and Privacy
Experience
Enable Cortana | Select this option to enable the Cortana personal digital assistant. |
System
Restrict Telemetry Data | Determines the amount of diagnostic and usage telemetry data sent to Microsoft. Choose one of the following levels:
Levels are listed in order of least to most data sent. |
Enable Location Service | Select whether location services on devices are enabled, disabled, or configurable by device users. |
Authentication
Enable EAP Fast Reconnect | Select this option to enable EAP Fast Reconnect to be attempted for EAP Method TLS. |
Require Internal Storage Encryption | Select this option to require internal storage to be encrypted. |
