Application Run Control
Use this dialog box to view and edit the device restrictions that have been added to this Application Run Control configuration. You do this when:
Note: This configuration requires an authentication configuration installed on the devices.
This section contains the following topics and folders:
Restrictions
Action on Device Select the type of action you want this configuration to have on the device:
  • Enforce: Implements the restrictions on the device as soon as the profile is assigned.
  • Audit: Logs the restrictions on the device but does not implement them. This enables you to test various restrictions before they are implemented. To access the logs on a Windows Modern Desktop device, open the Windows Event Viewer and navigate to Application and Services Logs > Microsoft > Windows > AppLocker.
Applications Click Add to open the Restrictions > Applications dialog box in which you can enter the details of an application you want to restrict.
