Client PFX Certificates
Use a Client PFX Certificates configuration to distribute Client PFX certificates to Windows Modern devices. You do this when:
You can select an existing certificate or you can select a template that SOTI MobiControl will use to dynamically generate a certificate that is specific to each user and device. For information about how to create a certificate template, see Adding Certificates.
Note: Client PFX certificates can be used on devices running Microsoft Windows 10 or later. This includes HoloLens for Business devices but not HoloLens devices.
Client PFX certificates installed on older devices will be ignored.
Trusted Certificates
(Windows Modern Desktop and HoloLens for Business) Target Certificate Store Select whether you want the certificate to be installed in the Device store or the User store.
Add Certificates Click the Import button to upload a certificate to SOTI MobiControl. Once it has been uploaded, the certificate will appear in the list where you can select it for the profile configuration.
