Email: IMAP Account
The IMAP Account email configuration enables you to configure IMAP account settings for your devices when:
Account Description
Account Name Enter the account name of your organization.
Reply Email Address Enter the reply email address.
Send Display Name Enter the sender display name.
User Enter the user name associated with your email account.
Password Enter the account password here.
Sync The Past Select the amount of time email will be synced.
Sync Interval Select the amount of time between each sync.
Incoming Server
Host Address Enter the IP address or hostname, and port number, for the incoming email server.
Use SSL This option allows the end user to select whether or not SSL is used for communication with the email server.
Accept All Certificates If using SSL, select this option to accept all certificates sent by the server.
User Enter the user name associated with your email account. Supports macros.
Email Configuration Enter the email address associated with your email account. Supports macros.
Outgoing Server
Host Address Enter the IP address or hostname, and port number, for the outgoing email server.
Alternative SMTP
Use Alternative SMTP Specify whether to use an alternative SMTP account. This is useful when access to primary SMTP server is not available.
Alternative User Name Specifies the display name associated with the user's alternative SMTP email account.
Alternative Password Specifies the password for the user's alternative SMTP account.
Alternative Domain Specifies the domain name for the user's alternative SMTP account.
