Vendor Compatibility Matrix: 802.1x Enterprise WiFi
Some device features may not be compatible with all MDM versions. Refer to the table below to see which features are supported by your MDM version.
| Feature Name | Generic | Plus | Samsung Signed | Amazon | Casio | DRS | Samsung ELM Signed | Honeywell | HTC | Huawei | Kyocera | Lenovo | LG | Motorola | Panasonic | Pidion | Sony | Unitech | Zebra | Enterprise |
| Use Certificate for WiFi EAP 802.1x | n/a | n/a | MDM 2.0 | All | MDM Plugin | n/a | MDM 4 | MDM Plugin | n/a | MDM Plugin | MDM Plugin | MDM Plugin | MDM 1.0 | MDM 4 | MDM Plugin | MDM Plugin | MDM 7+ | MDM Plugin | MDM 4 | L+ |
