Web Filter
The Web Filter configuration enables you to specify what URLs you want to block or allow. If a URL is blocked, a device user will not be able to access that URL.
| Add | Adds a URL to the filter list. Enter the URL and specify whether to block or allow the URL. |
| Edit | Enables you to edit the selected entry in the filter list. |
| Delete | Deletes the selected entry from the filter list. |
