Out of Contact
The Out of Contact configuration enables you to specify actions to be taken if a device has not reconnected with SOTI MobiControl within a specified period of time.
Device Side Action
Lists the out-of-contact time periods that will trigger an event, and the corresponding action for each event.
| Add | Opens the Event Configuration dialog box in which you can specify an out-of-contact time period and the script you want to run on the device when time period has elapsed. |
| Edit | Opens the Event Configuration dialog box in which you can edit the selected out-of-contact event. |
| Delete | Deletes the selected out-of-contact event from the list. |
