Application Run Control
The Application Run Control configuration enables you to control which applications are allowed to run on devices and which are blocked. To allow an application to run, you add it to a whitelist, and to block an application from running, you add it to a blacklist.
The Application Run Control dialog box displays two lists of application control lists: an Available Controls List and a Selected Controls List. When you first create an application control list it is added to the Available Controls List. When you want to apply the application control list to the configuration, you move it to the Selected Controls List.
| Available Controls List | This is the list of application control lists that have been created but not yet applied to the configuration. To apply an application control list, move it from the Available Controls List to the Selected Controls List. |
| Selected Controls List | This is the list of application control lists that have been applied to the configuration. |
| New | Opens the New Application Control List dialog box in which you can create either a blacklist or a whitelist of applications you want to control. |
| Edit | Opens the Edit Application Control List dialog box in which you can edit the list of applications you want to control. |
| Export | Saves the selected application control list to a file, so you can import it to another SOTI MobiControl instance. |
| Delete | Deletes the selected application control list. Only applications that are in the Available Controls List can be deleted. |
