New/Edit Application Control List
This dialog box lists the applications that have been added to this application control list. You can add new applications to the list, as well as edit or delete applications that are in the list.
| Name | Enter the name you want to give this application control list. |
| Type | Select whether this list is a blacklist (a list of blocked applications) or a whitelist (a list of allowed applications). |
| Add | Enables you to add an application to the list. |
| Edit | Enables you to edit the selected application in the list. |
| Delete | Deletes the selected application from the list. |
| Import File | Opens a dialog box in which you can select the application control list file you want to import to this list. |
