Add/Edit Profile
Use this tab to enter a name and description for the profile.
| Name | Enter a unique name for the profile. |
| Description | Enter a description of the profile. |
| Type | Select the Android device type for the profile: Android Plus, Samsung KNOX, or Android Enterprise. |
Configurations
| Add | Opens a menu from which you can select the configuration you want to add to the profile. |
| Action | Opens a menu with options to edit the selected configuration, delete the selected configuration, or delete all configurations. |
Packages
| Add | Opens the Add Package dialog box in which you can select the package you want to add to this profile. |
| Action | Opens a menu with options to delete the selected package, delete all packages, or define package dependencies. |
