Vendor Compatibility Matrix: Feature Control
Some device features may not be compatible with all MDM versions. Refer to the table below to see which features are supported by your MDM version.
| Feature Name | Generic | Plus | Samsung Signed | Amazon | Casio | DRS | Samsung ELM Signed | Honeywell | HTC | Huawei | Kyocera | Lenovo | LG | Motorola | Panasonic | Pidion | Sony |
| Block OS Upgrade | n/a | n/a | MDM 3+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | MDM 2.1+ | n/a | n/a | n/a | n/a |
| Data Roaming | n/a | 2.2+ | MDM 1+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.2+ | 2.2+ | 2.2+ | MDM 3+ | 2.2+ | MDM 1+ | 2.2+ | 2.2+ | 2.2+ | MDM 2 |
| Disable Addition of New Email Accounts | n/a | n/a | MDM 4+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable All Tethering | n/a | 4.0+ | MDM 2+ | 4.0+ | 4.0+ | 4.0+ | MDM 4+ | 4.0+ | 4.0+ | 4.0+ | MDM 3+ | 4.0+ | MDM 2+ | 4.0+ | 4.0+ | 4.0+ | MDM 1+ |
| Disable Background Data | n/a | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | n/a |
| Disable Bluetooth | n/a | 2.2+ | MDM 1+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | MDM 3+ | 2.2+ | MDM 1+ | 2.2+ | 2.2+ | 2.2+ | MDM 1+ |
| Allow Limited Bluetooth Discoverable Mode | n/a | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ |
| Disable Bluetooth Data Transfer | n/a | n/a | MDM 2+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable Bluetooth Desktop Pairing | n/a | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ |
| Disable Bluetooth Discoverable Mode | n/a | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | MDM 3+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ |
| Disable Bluetooth Pairing | n/a | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ |
| Disable Bluetooth Tethering | n/a | 4.0+ | MDM 2+ | 4.0+ | 4.0+ | 4.0+ | MDM 4+ | 4.0+ | 4.0+ | 4.0+ | MDM 3+ | 4.0+ | MDM 2+ | 4.0+ | 4.0+ | 4.0+ | n/a |
| Disable USB Tethering | n/a | 4.0+ | MDM 2+ | 4.0+ | 4.0+ | 4.0+ | MDM 4+ | n/a | 4.0+ | 4.0+ | MDM 3+ | 4.0+ | MDM 2+ | 4.0+ | 4.0+ | 4.0+ | n/a |
| Disable Camera | n/a | 2.3+ | MDM 1+ | 2.3+ | 2.3+ | 2.3+ | MDM 4+ | 2.3+ | 2.3+ | 2.3+ | 2.3+ | 2.3+ | 2.3+ | 2.3+ | 2.3+ | 2.3+ | 2.3+ |
| Disable Cellular data | n/a | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | n/a |
| Disable Clipboard | n/a | 3.0+ | MDM 2+ | 3.0+ | 3.0+ | 3.0+ | MDM 4+ | 3.0+ | 3.0+ | 3.0+ | MDM 3+ | 3.0+ | 3.0+ | 3.0+ | 3.0+ | 3.0+ | 3.0+ |
| Disable Factory Reset | n/a | n/a | MDM 2+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | MDM 3+ | n/a | MDM 1+ | n/a | n/a | n/a | n/a |
| Disable Google Backup | n/a | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | MDM 3+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | n/a |
| Disable GPS Mock Locations | n/a | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | n/a |
| Disable Home Key | n/a | n/a | MDM 2+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | MDM 2.1+ | MDM 3.4+ | n/a | n/a | n/a |
| Disable Incoming MMS Messaging | n/a | n/a | MDM 3+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable Incoming SMS Messaging | n/a | n/a | MDM 3+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable Installation From Unknown Sources | n/a | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | MDM 3+ | 2.2+ | MDM 1+ | 2.2+ | 2.2+ | 2.2+ | MDM 3+ |
| Disable Kies | n/a | n/a | MDM 2+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable Microphone | n/a | n/a | MDM 1+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | MDM 3+ | n/a | MDM 2+ | n/a | n/a | n/a | n/a |
| Disable Multi-User | n/a | ? | ? | ? | ? | ? | ? | ? | ? | ? | ? | ? | ? | ? | ? | ? | ? |
| Disable Multi-Window | n/a | n/a | MDM 4+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable NFC | n/a | 4.0+ | MDM 2+ | 4.0+ | 4.0+ | 4.0+ | MDM 4+ | 4.0+ | 4.0+ | 4.0+ | MDM 3+ | 4.0+ | MDM 2+ | 4.0+ | 4.0+ | 4.0+ | n/a |
| Disable Outgoing Calls Via Bluetooth | n/a | 4.0+ | MDM 2+ | 4.0+ | 4.0+ | 4.0+ | MDM 4+ | 4.0+ | 4.0+ | 4.0+ | 4.0+ | 4.0+ | 4.0+ | 4.0+ | 4.0+ | 4.0+ | n/a |
| Disable Outgoing MMS Messaging | n/a | n/a | MDM 3+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable Outgoing SMS Messaging | n/a | n/a | MDM 3+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable Portable WiFi Hotspot | n/a | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | MDM 3+ | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | n/a |
| Disable Portable WiFi Hotspot Changes | n/a | n/a | MDM 3+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable prompt for Credentials | n/a | n/a | MDM 2+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable removal of SOTI MobiControl agent | n/a | n/a | MDM 2+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | MDM 1+ | n/a | n/a | n/a | 4.4+ |
| Disable Roaming Syncing | n/a | 2.2+ | MDM 1+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | n/a | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | MDM 2+ |
| Disable Roaming WAP PUSH Messages | n/a | n/a | MDM 1+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable Screen Capture | n/a | n/a | MDM 2+ | n/a | MDM 1+ | n/a | MDM 4+ | n/a | n/a | n/a | MDM 3+ | n/a | MDM 1+ | n/a | n/a | n/a | MDM 3+ |
| Disable SD Card Access | n/a | 2.2+ | MDM 2+ | 2.2+ | MDM 1+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | MDM 3+ | 2.2+ | MDM 1+ | 2.2+ | 2.2+ | 2.2+ | MDM 1+ |
| Disable USB Debugging | n/a | 2.2+ | MDM 2+ | 2.2+ | MDM 1+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | MDM 3+ | 2.2+ | MDM 2 | MDM 3.4+ | 2.2+ | 2.2+ | MDM 3+ |
| Disable USB Mass Storage | n/a | 2.3+ | MDM 2+ | 2.3+ | 2.3+ | 2.3+ | MDM 4+ | 2.3+ | 2.3+ | 2.3+ | 2.3+ | 2.3+ | 2.3+ | MDM 3.4+ | 2.3+ | 2.3+ | MDM 3+ |
| Disable USB Media Player | n/a | n/a | MDM 2+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | MDM 3+ | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable USB On-the-Go | n/a | n/a | n/a | n/a | MDM 1+ | n/a | n/a | n/a | n/a | n/a | MDM 3+ | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable Voice Dialer/S-Voice | n/a | n/a | MDM 2+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | MDM 1+ | n/a | n/a | n/a | n/a |
| Disable WiFi | n/a | 2.2+ | MDM 1+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | MDM 3+ | 2.2+ | MDM 1+ | 2.2+ | 2.2+ | 2.2+ | MDM 1+ |
| Disable WiFi profile changes | n/a | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ |
| Disable WiFi Profiles | n/a | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ |
| Enforce GPS Availability | n/a | 2.3+ | MDM 2+ | 2.3+ | 2.3+ | 2.3+ | MDM 4+ | n/a | 2.3+ | 2.3+ | MDM 3+ | 2.3+ | MDM 1+ | 2.3+ | 2.3+ | 2.3+ | n/a |
| Enforce minimum WiFi Security Level | n/a | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | MDM 4+ | 2.3+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ | MDM 2+ | 2.2+ | 2.2+ | 2.2+ | 2.2+ |
| Prevent Uninstallation of Managed Apps | n/a | n/a | MDM 1+ | n/a | n/a | n/a | MDM 4+ | n/a | n/a | n/a | n/a | n/a | MDM 1+ | n/a | n/a | n/a | n/a |
| Disable changes to Battery Settings | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | 6.0+ | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable changes to Battery and Time | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | 6.0+ | n/a | n/a | n/a | n/a | n/a | n/a |
| Disable changes to Quick Settings | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | n/a | 6.0+ | n/a | n/a | n/a | n/a | n/a | n/a |
