Configure Application Settings
Use this dialog box to hide certain settings in the SOTI Surf app.
If a device has multiple profiles where the Application Settings conflict, the more restrictive setting will apply. That is, the setting will be enabled on the device.
| Hide Accessibility | When enabled, accessibility settings for SOTI Surf are hidden from the device users.
Enabling Hide Accessibility automatically enables all of its subsettings too. |
| Hide Text Scaling | When enabled, device users cannot see or access the Text Scaling option in the accessibility settings of the SOTI Surf app. |
| Hide Auto hide top and bottom bar | When enabled, device users cannot see or access the Auto hide top and bottom bar option in the accessibility settings of the SOTI Surf app. |
| Hide Full screen mode | When enabled, device users cannot see or access the Full screen mode option in the accessibility settings of the SOTI Surf app. |
| Hide Advanced | When enabled, device users cannot see or access the Advanced settings in the SOTI Surf app.
Enabling Hide Advanced automatically enables all of its subsettings too. |
| Hide Restore tabs on startup | When enabled, device users cannot see or access the Restore tabs on startup option in the SOTI Surf app. |
| Hide Open links in new tab | When enabled, device users cannot see or access the Open links in new tab option in the SOTI Surf app. |
| Hide URL suggestion | When enabled, device users cannot see or access the URL suggestion option in the SOTI Surf app. |
| Hide Download Location | When enabled, device users cannot see or access the Download location option in the SOTI Surf app. |
| Hide Reset Settings | When enabled, device users cannot see or access the Reset Settings option in the SOTI Surf app. |
| Specify Download Location | Select this option and click the Configure button to open the Configure Download Location dialog box in which you can specify a location for documents downloaded from the browser. |
