Renaming Groups
Once a group has been created, you can rename it at any time. This change is reflected on all existing incidents that belong to the group.
To rename a group:
- Select Settings from the main menu.
- Click the context menu to the right of the group name you want to rename.
- Select Rename to open the Rename Group dialog box.
- Edit the Group Name and Group Prefix fields as required.
- Click Save.
