Sending Scripts to Devices
For a full list of available script commands, see Using Script Commands in the SOTI MobiControl Help.
To send a script to a device:
				Start a remote-control session ( see Remotely Controlling Devices) for the device you want to send
					a script to.
				The remote-control page opens.
				At the top of the remote-control page, select the Menu button located to the
					right of the device name and select Send Script.
The Send Script dialog box opens. -
				On the left side of the Send Script dialog box, select one of the
					predefined scripts. Ff you want to create a new script from scratch, select
						One-Time Script.
If you select a predefined script, the script appears in the Script editing field where, if required, you can change it. -
				In the Script field, enter or change the script commands
					as required.
				For information about the syntax of each script command (see Using Script Commands in the SOTI MobiControl online help).
				When you finish editing the script, select the Send
						Script button.
				The Send Script dialog box closes and device receives the script.
Once the script has finished running on the device, you can check the results on the Remote Control page.
