Remote Control on Linux Devices
Accessing the Administration Console of Linux Devices
Note: Requires Linux device
                    agent version 14.3 or later.
To access the administration web console:
                    Select the Web Console tool. The web console login
                        page opens in a new browser window. Once you have logged in, you can
                        interact with the device's administration console as if you were on the same
                        network as the device.
Establishing a Remote Terminal Connection With a Linux Device
Note: Requires Linux device agent version 14.3 or
                    later.
To establish a remote terminal connection with a Linux
                    device:
                    Select the Terminal tool.
An SSH terminal window for the device opens. To download the output
                        of a terminal session, select the Download Session
                        button.
