Customizing Design Preferences
Use Design Preferences in the Account Settings to customize the following aspects of your SOTI Identity login experience.
- Select the menu on the top-left of the SOTI Identity admin console and navigate to .
To change your design preferences, refer to the table for more
information.
Task Procedure Changing Background Preferences Preset: Select from the available background options. Custom: Select and upload an image of your choice.
Changing Logo Preferences Preset: Select the default logo that is available. Custom: Select and upload an image of your choice.
Changing Color Preferences To change your text color: - Select the field and enter a HEX code color key, or select the icon to open the color palette window to choose your color.
- Select Save to keep your changes.
