For security-conscious organizations where privacy and information security concerns require controlling mobile data and other features, SOTI MobiControl provides diverse on-device restrictions. These include blocking certain device communications, similar to firewalls and more. You can configure feature control when:
You may also selectively turn off device features with the Feature Control profile configuration. Applying the configuration at the individual or group level creates custom profiles for different users and locations in an organization. For example, turning Bluetooth and infrared ports on or off determines if device users can beam business cards, applications, or documents to one another.
Device Functionality
Features
camera. Important: This feature is available and applies to Android devices running OS
6.0 or later. |
| Allow Screen Capture | When enabled, device users can save images or recordings of the display. |
Android devices running OS 6.0 or later.
capabilities. Important: This
OS 9.0 or later. Restriction: Not
| Allow Assist Content | When enabled, allows assist features to access and share contextual information. This includes contextual information such as screenshots or app data (for example, package name) from being sent to privileged applications like assistant apps (requires Android 15.0+). |
| Allow NFC | When enabled, allows Near-field Communication (NFC) to be turned on via Settings (requires Android 15.0+). |
| Allow Location Sharing for Work Profile | When enabled, you can enable location sharing for all managed profile apps. Apps running in the Work profile are unable to use device location information. |
When enabled, when a supported app launches for the first time, it skips any introductory hints or tutorials. Note: Not available on Android 11 COPE
devices.
Restriction: Not supported for AMAPI-enrolled
devices.
| Allow All Keyguard Features | When enabled, device users can use keyguard features on the lock screen. Keyguard features include fingerprint authentication, notification viewing, smart lock, and camera access. Enabling Allow All Keyguard Features automatically enables other keyguard options. |
to Android devices running OS 6.0 or later. |
This does not remove any existing accounts from the device. Note: For AMAPI-enrolled devices, No
Accounts is the only option
available. |
power to stay connected. Note: Not supported for
| Allow Verify Apps Enforcement | When enabled, the device user can change the Scan device for security threats option within the Google Play Store's Play Protect settings. |
| Play Integrity Attestation Frequency | When enabled, the device performs the SafetyNet check at every device check-in, in addition to once daily. |
| Allow Copy/Paste between Work and Personal | When enabled, device users can copy text or images between the Work and Personal profiles. |
| Allow Caller ID Information for Work Profile Contacts | When enabled, device users can see Caller ID information for calls from contacts saved within the Work profile. |
| Allow Installation from Unknown Sources | When enabled, device users can install apps other than those from the Google Play store. |
| Allow Installation from Unknown Sources on Personal | When enabled, device users
can install apps that are not from the Google Play store on the
personal profile of the device. Important: This feature is available and applies
to Android devices running OS 10.0 or later. |
| Allow Sharing from Work Profile to Personal | When enabled, device users can use
an app's share function to share between apps on the Work
profile and apps on the personal profile. Important: This feature is available and applies
to Android devices running OS 5.1.1 or later. |
| Allow Outgoing NFC | When enabled, device users can use NFC to send data
| Allow Bluetooth Contact Sharing | When enabled, device users can use
Bluetooth to share contact information. Important: This feature is available and applies
devices. |
Policy Messaging
Restriction Policy
This
Work Profile Wipe Message
Enter the message that should appear to device users when the device wipes all Android Work Profile data and deletes the Android Work Profile.
