For security-conscious organizations where privacy and information security concerns require controlling mobile data and other features, SOTI MobiControl provides diverse on-device restrictions. These include blocking certain device communications, similar to firewalls and more. You can configure feature control when:
You may also selectively turn off device features with the Feature Control profile configuration. Applying the configuration at the individual or group level creates custom profiles for different users and locations in an organization. For example, turning Bluetooth and infrared ports on or off determines if device users can beam business cards, applications, or documents to one another.
Device Functionality
Features
| Feature | Description | Profile |
camera. Important: This feature is available and applies to Android devices running OS
6.0 or later. |
W |
| Allow Screen Capture | When enabled, device users can save images or recordings of the display. | W |
| Allow Factory Reset | When enabled, device users can erase all applications,
settings, and data from the phone's internal storage. Restriction: Not supported for AMAPI-enrolled
devices. |
P, W Restriction: Not available on Android 11 COPE
devices.
| Allow Safe Boot | When enabled, you can reboot devices into safe boot mode.
However, SOTI MobiControl disables third-party
software in a safe boot. Important: This feature is available and applies
to Android devices running OS 6.0 or later. Restriction: Not supported for AMAPI-enrolled
devices. |
P, W |
P, W |
| Allow SMS | When enabled, the device can send and receive SMS. | P, W |
| Stay Awake while Charging | Determines who controls whether the device remains
awake while charging.
devices. |
P, W |
| Allow Keyguard Camera | When enabled, the device user can launch the camera
P, W |
| Allow Printing for Work Profile | When enabled, device users can use the device's printing
capabilities. Important: This
OS 9.0 or later. Restriction: Not
W |
| Allow Outgoing Cellular Phone Calls | When enabled, device users can not make outbound calls. Internet or Voice-over-IP (VoIP) are not blocked. | P, W |
When enabled, when a supported app launches for the first time, it skips any introductory hints or tutorials. Note: Not available on Android 11 COPE
devices.
devices.
P, W |
| Location Accuracy | Determines the accuracy of the location reporting data
and who controls that accuracy.
devices. |
P, W |
| Allow Date Time Management | When enabled, device users can configure the
device's date, time, and timezone settings. Important: This feature is
available and applies to Android devices running OS 9.0 or
later. |
P, W |
| Allow Screen Timeout Management | When enabled, device users can configure
screen timeout settings. Important: This feature is available and applies
to Android devices running OS 9.0 or later. Note: Not
available on Android 11 COPE devices. Restriction: Not supported for AMAPI-enrolled
devices. |
P, W |
| Allow Brightness Configuration Management | When enabled, device users can configure
brightness settings. Important: This feature is available and applies
devices. |
P, W |
| Allow Location Sharing for Work Profile | When enabled, you can enable location sharing for all managed profile apps. Apps running in the Work profile are unable to use device location information. | W |
Connectivity
Network Connections
| Allow Tethering Management | When enabled, device users can configure their device's
tethering (sharing a mobile device's data connection with
another device) settings. Available on Managed Device only. |
P, W |
| Allow Bluetooth Management | When enabled, device users can configure their
Bluetooth settings. Available on Managed Device only. |
P, W |
| Wi-Fi Management | When enabled, device users can configure Wi-Fi
configuration. Available on Managed Device only.
P, W |
| Allow VPN Management | When enabled, device users can configure their VPN
P, W |
| Allow Download of eSIMs | When enabled, allows downloading of eSIMs (requires Android 15.0+). |
Requires Android 15+. |
| Allow Network Settings Reset | When enabled, device users can reset their
network configurations from their settings. Important: This feature is
available and applies to Android devices running OS 6.0 or later. Available on Managed Device only. Note: Not supported for AMAPI-enrolled
devices. |
P, W Note: Not available on Android 11 COPE devices. |
| Minimum Wi-Fi Security Level | Set the minimum Wi-Fi security level that the
device can connect to. For example, if you set the minimum Wi-Fi
security level to WPA, the device can not connect to a WEP
network. Available on Managed Device only. |
P, W |
| Data Roaming | Determines who controls the data roaming settings on the
device.
P, W |
| Bluetooth | Determines who has control over the Bluetooth setting.
P, W |
| Wi-Fi | Determines who controls the Wi-Fi connection.
Available on Managed Devices only Note: Not
P, W |
Security Options
| Allow All Keyguard Features | When enabled, device users can use keyguard features on the lock screen. Keyguard features include fingerprint authentication, notification viewing, smart lock, and camera access. Enabling Allow All Keyguard Features automatically enables other keyguard options. | P, W |
to Android devices running OS 6.0 or later. |
P, W |
| Allow All Keyguard Notifications | When enabled, all notifications on secure
P, W |
| Allow Account Creation For Personal | Specify whether device users can add new personal accounts to the device. Select an
option from the list:
This does not remove any existing accounts from the device. SOTI MobiControl selects All by default. |
P |
| Allow Account Creation For Work | Specify whether device users can add new work accounts to the device. Select an
W |
power to stay connected. Note: Not supported for
P, W |
P, W |
| Allow All System UI | When enabled, system UI alerts appear to device users.
This includes toast messages, phone activities (including
priority), system alerts, system errors, and system
overlays. Available on Managed Devices only. Note: Not
P, W |
| Allow Verify Apps Enforcement | When enabled, the device user can change the Scan device for security threats option within the Google Play Store's Play Protect settings. | P, W |
| Play Integrity Attestation Frequency | When enabled, the device performs the SafetyNet check at every device check-in, in addition to once daily. | P, W |
| Allow Adding Private Profiles | When enabled, allows the adding of private profiles, which can be used as alternative user space for sensitive apps (requires Android 15.0+). | P, W |
| Allow Copy/Paste between Work and Personal | When enabled, device users can copy text or images between the Work and Personal profiles. | W |
P, W |
| Allow Uninstallation of Managed Applications | When enabled, device users can uninstall any managed applications. | W |
| Allow Third Party Input Methods | When enabled, device users can enable third-party input methods such as keyboards on their devices. | P, W |
| Allow Caller ID Information for Work Profile Contacts | When enabled, device users can see Caller ID information for calls from contacts saved within the Work profile. | W |
| Allow Installation from Unknown Sources | When enabled, device users can install apps other than those from the Google Play store. | W |
| Allow Installation from Unknown Sources on Personal | When enabled, device users
can install apps that are not from the Google Play store on the
personal profile of the device. Important: This feature is available and applies
to Android devices running OS 10.0 or later. |
P |
| Allow Sharing from Work Profile to Personal | When enabled, device users can use
an app's share function to share between apps on the Work
profile and apps on the personal profile. Important: This feature is available and applies
to Android devices running OS 5.1.1 or later. |
W |
| Allow Outgoing NFC | When enabled, device users can use NFC to send data
W |
| USB Debugging | Determines who controls the device's ability to enter USB
Debugging mode.
P, W |
| Allow USB File Transfer and USB Storage | When enabled, device users can transfer data
SOTI MobiControl enables this option by default. Note: AMAPI-enrolled devices have
deprecated the usbMassStorageEnabled
property. |
P, W |
| Allow Bluetooth Contact Sharing | When enabled, device users can use
Bluetooth to share contact information. Important: This feature is available and applies
P, W |
devices. |
P, W |
| Allow 2G Connectivity | Warning: Enabling this
setting increases the risk to security and privacy.
When enabled, device users can control whether to
enable/disable 2G connectivity. Note: Not
W |
| Allow Ultra-Wideband Connectivity | When enabled, device users can control whether to
enable/disable ultra-wideband connectivity. Note: Not supported for AMAPI-enrolled
devices. |
W |
Policy Messaging
Restriction Policy
This
