For security-conscious organizations where privacy and information security concerns require controlling mobile data and other features, SOTI MobiControl provides diverse on-device restrictions. These include blocking certain device communications, similar to firewalls and more. You can configure feature control when:
You may also selectively turn off device features with the Feature Control profile configuration. Applying the configuration at the individual or group level creates custom profiles for different users and locations in an organization. For example, turning Bluetooth and infrared ports on or off determines if device users can beam business cards, applications, or documents to one another.
Device Functionality
Features
camera. Important: This feature is available and applies to Android devices running OS
6.0 or later. |
| Allow Screen Capture | When enabled, device users can save images or recordings of the display. |
| Allow Factory Reset | When enabled, device users can erase all applications,
settings, and data from the phone's internal storage. Restriction: Not supported for AMAPI-enrolled
devices. |
| Allow Safe Boot | When enabled, you can reboot devices into safe boot mode.
However, SOTI MobiControl disables third-party
software in a safe boot. Important: This feature is available and applies
to Android devices running OS 6.0 or later. Restriction: Not supported for AMAPI-enrolled
devices. |
| Allow SMS | When enabled, the device can send and receive SMS. |
| Stay Awake while Charging | Determines who controls whether the device remains
awake while charging.
devices. |
| Allow Status Bar | When enabled, you can expand the status bar to view
device notification details. Important: This feature is available and applies
to Android devices running OS 6.0 or later. |
| Allow Keyguard Camera | When enabled, the device user can launch the camera
| Allow Microphone | When enabled, the device user can use the microphone to record audio. |
| Allow Airplane Mode | When enabled, device users can turn on Airplane mode.
available and applies to Android devices running OS 9.0 or
later. |
| Allow Ambient Display | When enabled, device users can turn on Ambient
Display. Important: This
OS 9.0 or later. |
| Allow Device Volume | When enabled, the volume settings are visible to and
changeable by the device user. Important: This feature is available and applies
to Android devices running OS 9.0 or later. |
capabilities. Important: This
OS 9.0 or later. Restriction: Not
| Allow Assist Content | When enabled, allows assist features to access and share contextual information. This includes contextual information such as screenshots or app data (for example, package name) from being sent to privileged applications like assistant apps (requires Android 15.0+). |
| Allow NFC | When enabled, allows Near-field Communication (NFC) to be turned on via Settings (requires Android 15.0+). |
| Allow Certificate Management | When enabled, device users can configure stored credentials (certificates) in the device's settings. |
| Allow App Management | When enabled, device users can configure or uninstall apps (and app data). This includes disabling the ability to force close an app, clear app data, app caches, and app default launch settings. |
| Allow Outgoing Cellular Phone Calls | When enabled, device users can not make outbound calls. Internet or Voice-over-IP (VoIP) are not blocked. |
When enabled, when a supported app launches for the first time, it skips any introductory hints or tutorials. Note: Not available on Android 11 COPE
devices.
devices.
| Location Accuracy | Determines the accuracy of the location reporting data
and who controls that accuracy.
devices. |
| Allow Date Time Management | When enabled, device users can configure the
device's date, time, and timezone settings. Important: This feature is
later. |
| Allow Screen Timeout Management | When enabled, device users can configure
screen timeout settings. Important: This feature is available and applies
to Android devices running OS 9.0 or later. Note: Not
available on Android 11 COPE devices. Restriction: Not supported for AMAPI-enrolled
devices. |
| Allow Brightness Configuration Management | When enabled, device users can configure
brightness settings. Important: This feature is available and applies
devices. |
Connectivity
Network Connections
| Allow Mobile Network Management | Prevents the user from making changes to the mobile network settings through the device's settings application. |
| Allow Tethering Management | When enabled, device users can configure their device's
tethering (sharing a mobile device's data connection with
another device) settings. Available on Managed Device only. |
| Allow Bluetooth Management | When enabled, device users can configure their
Bluetooth settings. Available on Managed Device only. |
| Wi-Fi Management | When enabled, device users can configure Wi-Fi
configuration. Available on Managed Device only.
| Allow VPN Management | When enabled, device users can configure their VPN
| Allow Download of eSIMs | When enabled, allows downloading of eSIMs (requires Android 15.0+). |
| Allow Network Settings Reset | When enabled, device users can reset their
network configurations from their settings. Important: This feature is
available and applies to Android devices running OS 6.0 or later. Available on Managed Device only. Note: Not supported for AMAPI-enrolled
devices. |
| Allow Download of eSIMs | Prevents access to downloading eSlMs (requires Android 15.0+). |
| Allow only SOTI MobiControl-managed WiFi | If enabled, the device only connects to Wi-Fi networks sent via SOTI MobiControl and blocks all other
networks. Important: This
feature applies to devices running Android OS 13 or
later. |
| Minimum Wi-Fi Security Level | Set the minimum Wi-Fi security level that the
device can connect to. For example, if you set the minimum Wi-Fi
security level to WPA, the device can not connect to a WEP
network. Available on Managed Device only. |
| Data Roaming | Determines who controls the data roaming settings on the
device.
| Bluetooth | Determines who has control over the Bluetooth setting.
| Wi-Fi | Determines who controls the Wi-Fi connection.
Available on Managed Devices only Note: Not
Security Options
| Allow All Keyguard Features | When enabled, device users can use keyguard features on the lock screen. Keyguard features include fingerprint authentication, notification viewing, smart lock, and camera access. Enabling Allow All Keyguard Features automatically enables other keyguard options. |
| Allow All Keyguard Notifications | When enabled, all notifications on secure
This does not remove any existing accounts from the device. Note: For AMAPI-enrolled devices, No
Accounts is the only option
available. |
power to stay connected. Note: Not supported for
| Allow All System UI | When enabled, system UI alerts appear to device users.
This includes toast messages, phone activities (including
priority), system alerts, system errors, and system
overlays. Available on Managed Devices only. Note: Not
| Allow Verify Apps Enforcement | When enabled, the device user can change the Scan device for security threats option within the Google Play Store's Play Protect settings. |
| Play Integrity Attestation Frequency | When enabled, the device performs the SafetyNet check at every device check-in, in addition to once daily. |
| Allow Adding Private Profiles | When enabled, allows the adding of private profiles, which can be used as alternative user space for sensitive apps (requires Android 15.0+). |
| Allow Caller ID Information for Work Profile Contacts | When enabled, device users can see Caller ID information for calls from contacts saved within the Work profile. |
| Allow Installation from Unknown Sources | When enabled, device users can install apps other than those from the Google Play store. |
| Allow Multi-User Control | When enabled, device users can add secondary users or remove added secondary users. |
| Allow Mounting Physical External Media | When enabled, device users can mount
physical external media (including SD cards) to their devices.
Note: This does not disable external media through the
device's charging port. See Allow USB File
Transfer and USB Storage. |
| Allow Outgoing NFC | When enabled, device users can use NFC to send data
| USB Debugging | Determines who controls the device's ability to enter USB
Debugging mode.
| Allow USB File Transfer and USB Storage | When enabled, device users can transfer data
SOTI MobiControl enables this option by default. Note: AMAPI-enrolled devices have
deprecated the usbMassStorageEnabled
property. |
devices. |
| Allow 2G Connectivity | Warning: Enabling this
setting increases the risk to security and privacy.
When enabled, device users can control whether to
enable/disable 2G connectivity. Note: Not
| Allow Ultra-Wideband Connectivity | When enabled, device users can control whether to
enable/disable ultra-wideband connectivity. Note: Not supported for AMAPI-enrolled
devices. |
Policy Messaging
Restriction Policy
This
