Client PFX Certificates
Use a Client PFX Certificates configuration to distribute Client PFX certificates to Windows Modern devices. Do this when you perform the following actions:
You can select an existing certificate or you can select a template that SOTI MobiControl uses to dynamically generate a certificate that is specific to each user and device. For more information on how to create a certificate template, see Adding Certificates.
Note: Client PFX certificates can be used on devices running Microsoft Windows 10 or later.
		Client PFX certificates installed on older devices are ignored.
Trusted Certificates
| (Windows Modern Desktop) Target Certificate Store | Select whether you want the certificate to be installed in the Device store or the User store. |
| Add Certificates | Select the Import button to upload a certificate to SOTI MobiControl. After the certificate is uploaded, it is displayed in the list where you can select the certificate for the profile configuration. |
