Email: IMAP Account
The IMAP Account email configuration enables you to configure IMAP account settings for your devices when you are:
Account Description
| Send Display Name | Enter the sender display name. |
| User | Enter the user name associated with your email account. |
| Sync The Past | Select the amount of time email will be synced. |
Incoming Server
| Host Address | Enter the IP address or hostname, and port number, for the incoming email server. Note: This field is case sensitive. |
| Accept All Certificates | If using SSL, select this option to accept all certificates sent by the server. |
| User | Enter the user name associated with your email account. Supports macros. |
| Email Configuration | Enter the email address associated with your email account. Supports macros. |
Outgoing Server
| Host Address | Enter the IP address or hostname, and port number, for the outgoing email server. Note: This field is case sensitive. |
Alternative SMTP
