Configuring Phone Calls
Use the Phone Calls configuration to block specific phone numbers or entire area codes on your devices. You can add numbers manually or bulk import them using a plain text (.txt) or .csv file.
Use the Phone Calls profile configuration to:
  • Block specific phone numbers to prevent unwanted or unauthorized communication.
  • Restrict entire area codes to control calls from specific regions.
  • Enhance security by reducing the risk of phishing or scam calls to or from managed devices.
  • Improve productivity by minimizing personal or non-business-related phone calls.
Note: This profile is available for Android Classic, Android Enterprise Work Managed, and Windows Mobile/CE.
To create a Phone Calls profile:
  1. Create or edit a Phone Calls profile. See Creating a Profile and Editing a Profile.
  2. In the Add Profile Configuration panel, select Phone Calls.
  3. In the Restrictions section, configure restrictions on incoming and outgoing calls for your devices.
  4. In the Phone Calls panel, select the icon to create a new list.
    1. Select the call direction (Incoming, Outgoing, Both)
    2. Select the call type (Allowor Deny)
  5. In the Add Phone Numbers section:
    • Select to import a file that contains phone numbers.
    • Select to add new phone numbers.
    Note: The imported file must be in plain text (.txt) format, with one phone number per line, and must not exceed 2000 lines. Each phone number must contain only digits, without dashes, spaces, or other separators.
    Tip: For more information on managing large groups of phone numbers, see Using Wildcard Characters.
  6. Select OK. The new phone number(s) are added to the Phone Calls section.
  7. To configure these new phone number(s), enable the toggle button located on the same row.
  8. Optional: Toggle on the available options in the profile configuration:
    Option Description
    Notify Server When Call is Blocked Records all incoming and outgoing blocked calls to the server log.
    Notify Device User When Call is Blocked Displays a message to the device user when the device receives a call from a blocked phone number.
  9. Select Save.
You have successfully configured the Phone Calls profile configuration for your devices to restrict incoming and outgoing calls.
SOTI MobiControl supports the use of the asterisk (*) and question mark (?) wildcard characters to indicate a range of phone numbers. An asterisk matches zero or more digits and a question mark matches one digit. Use wildcard characters to simplify managing large groups of phone numbers in your Phone Calls profile configuration.
    4445551230
    4445551231
    4445551232
    4445551233
    4445551234
    4445551235
    4445551236
    4445551237
    4445551238
    4445551239
You can also use the two wildcard characters in combination. For example, 4??55512* matches 4325551234, but does not match 4324321234.
