Settings Manager Settings
The Settings Manager app provides controlled access to a subset of device settings while a device is in lockdown mode. Choose from the listed device settings when configuring the Settings Manager app using the Settings Manager profile configuration. Do this when you perform the following actions:
Display
| Setting in Profile Configuration | Description | Setting In XML Configuration |
| Adaptive Brightness | When enabled, the device user can control the adaptive brightness setting for their device. | brightnessSeek |
| Brightness | When enabled, the device user can set the brightness level of their display. | brightnessAuto |
| Screen Rotation | When enabled, the device user can decide if their display remains in Portrait mode persistently or rotates automatically as the device changes position. | AutoRotate |
| Screen Timeout | When enabled, the device user can set a period after which the device screen times out and goes to sleep. | screenTimeout |
Sound
| Ringtone Volume | When enabled, the device user can control the volume of the ringtone on their device. | ringtoneVolume |
| Media Volume | When enabled, the device user can control the volume of any media they play on their device. | mediaVolume |
| Notification Volume | When enabled, the device user can adjust the volume of notifications on the device. | notificationVolume |
| System Volume | When enabled, the device user can control the volume of their device. | systemVolume |
WiFi
| Enable | When enabled, the device user has access to WiFi connectivity settings. | wifiOnOff |
| Scan | When enabled, the device can scan for available WiFi networks. | wifiScan |
| Add | When enabled, the device user can add new WiFi networks. | wifiAdd |
| Modify | When enabled, the device user can change WiFi network settings. | wifiModify |
Bluetooth
| Enable | When enabled, the device has access to Bluetooth. | btOnOFf |
| Visible | When enabled, the device is visible to other Bluetooth enabled devices. | btMakeVisible |
| Pair | When enabled, the device can pair with other Bluetooth enabled devices. | btPairUnpair |
| Scan | When enabled, the device can scan for other visible Bluetooth enabled devices. | btScan |
Time Zone
| Enable | When enabled, the device has access to Time Zone. | timeZoneOnOff |
| Manual Sync to SNTP server | When enabled, the device can synchronize with the SNTP server to manually update the date and time. | syncWithSntpServer |
| SNTP Server | The device can synchronize and update the date and time according to the defined server. | sntpServer |
Manage Access Point Name
| Manage Access Point Name | When enabled, the device user can create, change, view and delete the APNs. | manageAccessPointNameOnOff |
Manage Device Security
| Manage Device Security | When enabled, the device user can set new pin or password. | manageDeviceSecurityOnOff |
Flashlight
| Flashlight | When enabled, the device user can use device flashlight. | flashlightOnOff |
