Email: POP3 Account
The POP3 Account email configuration enables you to configure POP3 account settings for your devices when you are:
Connection
| Common Access Card Authentication | Use Common Access Card (CAC) for authentication. |
Incoming Server
| Host Address | Enter the IP address or hostname, and (optionally) the port number, for the email server.
| Security | Select the protocol used for mail data communication. |
Outgoing Server
