Email: IMAP Account
The IMAP Account email configuration enables you to configure IMAP account settings for your devices when you are:
Connection
| IMAP Prefix | Specify IMAP Incoming Server Prefix. |
| Common Access Card Authentication | Use Common Access Card (CAC) for authentication. |
Incoming Server
| Host Address | Enter the IP address or hostname, and (optionally) the port number, of the email server.
| Security | Select the protocol used for mail data communication. |
Outgoing Server
| Host Address | Enter the IP Address or hostname, and (optionally) the port number, of the email server.
