Creating a New Signal Policy
Signal Policy creation is a four to five step guided process that lets you to build your policy by:
- Adding general descriptive details about your policy.
- Building Signal Policy Conditions that triggers the policy. You can add many common category conditions (for example, Managed Devices) and many different condition groups (for example, Managed Devices condition groups) to built nested conditions.
- Adding Signal Policy Actions that SOTI MobiControl executes under specific conditions.
- (If applicable) Configuring Signal Policy Settings for certain Signal Policy Conditions that requires further configuration.
- Defining Signal Policy Schedules (optional) that control when the Signal Policy takes effect.
- Open the Policies > Signal view from the main menu.
- Select New Signal Policy to launch the Signal wizard.
Type a Name and Description for
your Signal Policy.
- Select Next to build the conditions for your policy, as described in Building Signal Policy Conditions.
