Configuring Signal Policy Settings
Signal policy settings offer advanced configuration options depending on the selected condition type. SOTI MobiControl can configure supported devices to evaluate specific Signal Managed Device properties at a defined frequency.
Restriction:
- Based on the platform, device side evaluations are available for the following managed device properties: List of Device Side Evaluation Properties.
- The Outdoor Geofence Power Policy is only available for the following
event attributes (for Conditions).
- Enter Outdoor Geofence
- Exit Outdoor Geofence
Select Settings to navigate to the
Settings tab.
Toggle on Enable Device Side Evaluation.
Select a frequency of evaluation for your conditions.
If you have selected Enter Outdoor Geofence or Exit Outdoor
Geofence, you have access to Outdoor Geofence Power
Policy.
You can choose from:
- Continuous: Continuously check for the device's location but uses more battery.
- Periodic: Check the device's location every
preset interval, enter a number and then choose from one of periods:
- Minutes
- Hours
- Days
- Weeks
