Adding SOTI Connect Integration
To configure SOTI Connect integration in your SOTI MobiControl instance:
- From the Settings tree on the left, select SOTI Connect page (see SOTI Xsight). to display the
- Enter a URL for the SOTI Connect server.
- Click Save.
