Set Up Policy
Use the Set Up Policy tab to set identify your policy.
![Linux Set Up Policy form](../common/../../../../../../media/images/screencaptures/policy_filesync_linux_setup.png)
In Set Up Policy, complete or update the following
information:
Name Enter a name for the policy. This field is mandatory. Description Describe how or where the policy will be used. - Select Next. The Configure tab opens. Continue to the Configure tab of the File Sync Policy wizard.
