Configure Network Settings
Select the network types you want to allow the SOTI Surf app to use to access the Internet.
If a device has multiple profiles with conflicting network settings, settings from all profiles will be unioned.
| Cellular | Enable SOTI Surf to use cellular networks. |
| Roaming | Enable SOTI Surf to use cellular networks while roaming. |
| Wi-Fi | Enable SOTI Surf to use WiFi networks. |
