Kiosk Mode
Kiosk mode replaces the standard device home screen with a customizable home screen that provides access only to authorized applications and websites.
| New | Opens the Add Menu Item dialog box in which you can specify the settings for a new kiosk menu item. |
| Edit | Opens the Add Menu Item dialog box in which you can edit the settings for the selected kiosk menu item. |
| Delete | Deletes the selected kiosk menu item. |
| Move Up | Moves the selected menu item one position higher in the menu order. |
| Move Down | Moves the selected menu item one position lower in the menu order. |
| Templates | Opens the Edit Menu Template List dialog box in which you can add, edit, or delete the menu items that appear in the template list. |
| Advanced | Opens the Advanced Kiosk Settings dialog box in which you can specify advanced settings for kiosk mode. |
