Feature Control: Android Enterprise
Hardware
| Disable Camera | When enabled, the device loses camera functionality. All apps in the Work profile will be prevented from launching the camera Android OS compatibility: 6.0 or later. Available on Managed Profile only. |
| Disable Screen Capture | When enabled, device users cannot take and save an image or a recording of the device's display. |
| Disable Factory Reset | When enabled, device users cannot complete a factory reset of the device through the settings menu. Factory reset is still possible using hardware key combinations. Available on Managed Device only. |
| Disable Safe Boot | When enabled, devices cannot be rebooted into safe boot mode (all third-party software is disabled in safe boot). Android OS compatibility: 6.0 or later. Available on Managed Device only. |
| Disable Smart Lock | When enabled, device users cannot use Smart Lock on Android which allows devices to unlock without a password when they are within 'safe' places that the device user sets. Android OS compatibility: 6.0 or later. Available on Managed Profile only. |
| Disable SMS | When enabled, the device cannot send or receive SMS. Available on Managed Device only. |
 Available on Managed Device only |
| Disable Status Bar | When enabled, the status bar cannot be expanded to view the details of device notifications. Android OS compatibility: 6.0 or later. Available on Managed Device only. |
| Disable Keyguard Camera | When enabled, the device user cannot launch the camera app from the lock screen. Available on Managed Device only. |
Cellular Data and Roaming
| Copy/Paste | Limits the device user's ability to share corporate data by restricting when they can copy and paste text and images.
| Redact Notifications | When enabled, notifications from Android Enterprise Apps are stripped of details when they appear on secure lock screens. Android OS compatibility: 6.0 or later. Available on Managed Profile only. |
| Disable Managed App Uninstallation | When enabled, device users cannot uninstall any managed applications. |
| Disable Third Party Input Methods | When enabled, device users cannot enable additional third-party input methods such as keyboards on their devices. Third-party input methods that are already enabled can still be used. |
| Disable Caller ID Information for Work Contacts | When enabled, device user cannot see Caller ID information for calls from contacts saved within the Work profile. |
| Disable Installation from Unknown Sources | When enabled, device users cannot install apps that are not from the Google Play store. Available on Managed Device only. |
| Disable Multi-User Control | When enabled, device users cannot add (or remove previously added) secondary users. Available on Managed Device only. |
| Disable Mounting SD Card | When enabled, devices cannot mount an SD card to their device. SD cards that already mounted remain connected. Available on Managed Device only. |
| Allow Sharing from Work to Personal Profile | When enabled, device users can use an app's Share function to share between apps on the Work profile to apps on the Personal profile. Android OS compatibility: 5.1.1 or later. Available on Managed Profile only. |
| Disable Outgoing NFC | When enabled, devices users cannot use NFC to send data (only applies to apps in the Work Profile). Available on Managed Profile only. |
| Disable Bluetooth Contact Sharing | When enabled, device users cannot use Bluetooth to share contact information. Android OS compatibility: 6.0 or later. Available on Managed Profile only. |
| Disable USB Debugging | Determines who controls the device's ability to enter USB Debugging Mode.
| Disable USB File Transfer | When enabled, device users cannot transfer data using a USB connection. Available on Managed Device only. |
| Disable Certificate Management | When enabled, device users cannot modify stored Credentials (Certificates) in the device's settings. Available on Managed Device only. |
| Disable Tethering Management | When enabled, device users cannot modify their device's tethering (sharing a mobile device's data connection with another device) settings. Available on Managed Device only. |
| Disable App Management | When enabled, device users cannot uninstall or modify apps (and app data). This includes disabling the ability to force close an app, clear app data, app caches, and app default launch settings. Available on Managed Device only. |
| Disable Bluetooth Management | When enabled, device users cannot modify their device's Bluetooth settings. Device users can still enable or disable Bluetooth. Available on Managed Device only. |
| Disable WiFi Management | When enabled, device users cannot modify WiFi configurations in their device's settings. Available on Managed Device only. |
| Disable VPN Management | When enabled, device users cannot modify their device's VPN settings. Available on Managed Device only. |
| Disable Network Settings Reset | When enabled, device users cannot reset their network configurations from their device's settings. Android OS compatibility: 6.0 or later. Available on Managed Device only. |
| Disable Location Sharing for Managed Profile | When enabled, Location Sharing is disabled in all Managed Profile apps. Apps running in the Work profile will be unable to use device location information. Available on Managed Profile only. |
| Disable Outgoing Cellular Phone Calls | When enabled, device users cannot initiate outbound calls. Internet or Voice-over-IP (VOIP) are not blocked. Available on Managed Device only. |
| Disable Fingerprint Authentication | When enabled, device users cannot use Google's fingerprint authentication framework to secure their devices. Android OS compatibility: 6.0 or later. Available on Managed Profile only. |
| Disable All Notifications | When enabled, all notifications on secure lock screens are hidden from device users. Available on Managed Device only. |
