							| Display Name of APN | Enter a name for the APN that is displayed on the device. |
							| Access Point Name (APN) | Enter the name or web address of the access point provided by your wireless carrier. |
							| Mobile Country Code (MCC) | Select the three digit code, as defined by the ITU, that identifies the network's country of origin. |
							| Mobile Network Code (MNC) | Select the mobile network code. The list contains all available mobile networks in the selected country. |
							| Access Point Type | Select the access point type. |
							| Access Point Custom Type | Enter the custom access point type. |
							| Default Connection | Select this option to make this the default APN connection for devices. |
							| Roaming | Specify whether the connection should be activated when the device is roaming. |
							| SIM Card ICCD | Specify the SIM Integrated Circuit Card ID (ICCID) that services this connection. Use this option with dual-SIM card devices to determine which SIM card will be used for the APN connection. |
Server
							| Access Point Connection Username | Enter the APN username provided by your wireless carrier. |
							| Access Point Connection Password | Enter the APN password provided by your wireless carrier. |
							| Server Address | Enter the hostname or IP address of the server provided by your wireless carrier. |
							| Port | Enter the port number of the server. |
							| Type | Select the proxy type. |
							| Server | Enter the name of the proxy server. |
							| Port | Enter the port number of the proxy server. |
							| Bypass Local | Select this option to enable the proxy to be bypassed when local hosts are accessed by the device. |
							| Exception | Enter a list of external hosts which should bypass the proxy when accessed. The exception list is a semicolon delimited list of host names. |
							| Enable | Select this option to enable the proxy. |
							| Qualified Proxy Server Address | Enter the hostname or IP address of the proxy server. |
							| Qualified Proxy Server Port | Enter the port number of the proxy server. |
							| MMS Proxy Server Address | Enter the MMS proxy server address provided by your wireless carrier. |
							| MMS Server Address | Enter the MMS server address provided by your wireless carrier. |
							| Port | Enter the MMS server port number provided by your wireless carrier. |
							| Authentication Type | Select the type of authentication used for the APN connection. |
