Configure Intranet Gateway Settings
Use this dialog box to set up an Enterprise Resource Gateway (ERG) for SOTI Surf. ERG routes your web traffic through a proxy server and grants your device users access to your internal network. You must have ERG configured on a proxy server to use this feature. Refer to Installing the SOTI Apps Server Extension for more information. Once ERG is set up, you can link your server to the SOTI Surf app through the SOTI Surf configuration.
It is possible to assign multiple profiles to the same device with different SOTI Surf configuration settings. If one profile has Use Intranet Gateway enabled and another profile that targets the same device, does not, then only the enabled profile applies. Also, if you assign multiple proxy servers to the same device through multiple profiles, the device will only use the settings of the first assigned proxy and ignore all subsequent proxy servers. However, if the multiple profiles contain the same proxy settings (as in the same IP address or FQDN and the same port number) then all the domains of each matching profile will be applicable.
| Address | Enter the address of the proxy of your ERG as an IP address or as a fully qualified domain name (FQDN). |
| Port | Enter the port number of your ERG. |
| Click here to add a new domain | Enter any domains that you want to route through the proxy server. You can add multiple domains. |
| Import | Opens the Import Gateway Domains dialog box in which you can import multiple domains from a file. The import file must be in .csv or .txt format with one domain per row. |
| Delete All | Deletes all domains from the list. |
