Configuring Battery Dashboard Results
The Smart Battery Dashboard displays information according to parameters you select. Use the following methods to customize your view of battery data:
- Selecting a battery pool
- Customizing the dashboard header
- Customizing the Battery Prediction chart
- Customizing the Charge Level chart
![The Smart Battery Dashboard](../media/images/screencaptures/smart_battery_dashboard_overview.png)
