Customizing The Smart Battery Header
You can configure the data on the Smart Battery Dashboard by selecting criteria from the header at the top of the dashboard.
To view batteries according to status, select In Use, All, New, or
Decommissioned from the Status dropdown
menu.
To view batteries according to search criteria, click inside the search field
and select from the following:
- Battery Serial Number
- Batter Part Number
- Device manufacturer
- Device Model
- Device Name
- Device ID
- Battery Health
- Battery Cycles
- Battery Age
- Last Device ID
Optionally, select one of the following boolean operators:
- Contains
- Not Contains
- Equal
- Not Equal
- Starts With
- Not Starts With
- Ends With
- Not Ends With
- You can also enter text in the free text field.
Click the plus button
to add another set of search criteria.
Click the magnifying glass
button to execute the search. The charts and Batteries list
change to reflect your search.
