Filtering Smart Battery Information
Filter the data on the Smart Battery dashboard by selecting criteria from the header at the top of the dashboard.
To view batteries according to status, select Dashboard
and choose In Use, All, New, or Decommissioned.
To view batteries according to search criteria, select search and choose from
the following:
Property Choose from: - Battery Serial Number
- Battery Part Number
- Device Manufacturer
- Battery Manufacturer
- Device Model
- Device Name
- Device ID
- Battery Charge Cycles
- Battery Age (Months)
Operator Select the operator to filter the selected property in relationship to the search text. For example: Battery Serial Number = Equals N4424
Note: The available operators change based on the property selected.Search text Enter the text value to search for. - Optional:
Select Add
Condition to add more search criteria.
Note: You may also select Delete to remove an individual condition or select Clear to remove all conditions and start again.
- Select Search.
