Create and Assign Compliance Policy for Conditional Access
- From the SOTI MobiControl main menu, select .
- Select New Compliance Policy. The Create Compliance Policy panel appears.
- Select the necessary platform. The Create Compliance Policy window appears.
- Enter a name for the policy then select Next. The Non-Compliance Policy screen appears.
- Select Add a Filter then select Device Mode as Is Not Active. Then, select Done.
Select
beside Policy Actions then, from the Action Type drop-down menu, select
Report Compliance Status to Microsoft Entra ID.
- Select Add Action. The action is added to the policy.
- Select Save or Save And Assign.
