Viewing Device Location History
You must have a Data Collection Policy configured and enabled in SOTI MobiControl with Location selected as a data collection point (see Using Data Collection Policies). This ensures that GPS data is collected and stored for historical reporting in SOTI XSight.
See a timeline of a device’s past movements, using SOTI XSight Live View after enabling location data collection in SOTI MobiControl.
  1. Log into the SOTI MobiControl web console as administrator.
  2. From the main menu, select Devices.
    Select Devices from the main menu
  3. In the Devices view, select the device.
    Select a device in the Devices panel
    The Device Details panel displays.
  4. In the Device Details panel, select the Policies tab. In the Data Collection section, ensure the device has an assigned data collection policy. Take note of the Data Collection Policy name field.
    Ensure the device has an assigned data collection policy
  5. From the main menu, select Policies.
    From the main menu select Devices
  6. Select the Data Collection tab.
  7. In the Data Collection Policies view, select the Data Collection Policy name noted in step 4.
  8. In the Data Collection panel, select the Policy Details page, in the Settings section, ensure the Collected Items field contains Location.
    Ensure Location is in the Collected items field.
  9. Navigate back to the Device Details panel for the device and select Collected data.
    Select the Collected data tab in the Device Details page
  10. In the Data type field, enter 'Location'. The location data associated with the device displays.
    Entery "location" in the Data Type field
  11. Select a time range to filter the historical data you want to view (green box in above image).
  12. Select the ‘Map’ button (yellow box in above image). This opens SOTI XSight Live View in a new tab with the collected data represented on the map as a route showing the device locations over the selected time range.
    View the device details from the device icon or any of the vertices on the route
    Note: The device icon marks its last known location within the selected time range. All recorded positions during that period appear as a route on the map (illustrated by the purple path above). To view details for a specific point, select either the device icon or one of the blurred location markers—typically positioned at route vertices. The red circle highlights an example of a blurred location image. Selecting it reveals device information, including timestamp and precise latitude/longitude coordinates.
You are able to see the movements of the device, as collected by the data collection policy, and plotted on the map in SOTI XSight.
