Creating an App Policy for Microsoft Shared Mode Registration of Android Enterprise Work Managed Devices
Use SOTI MobiControl to create and configure a conditional access policy
for Microsoft Shared Mode registration of Android work managed devices.
Note: To use Microsoft Shared mode with SOTI MobiControl v2024.0.0 and later, you need to change devices
registered as Microsoft User Mode to Microsoft Shared Mode in Microsoft Entra
ID. See How To
Convert a User Mode Registration to a Shared Mode Registration for
details.
Creating the Policy
- From the SOTI MobiControl hamburger menu, select . The App Policies view opens.
- Select New App Policy. The Create App Policy panel displays.
- Select . The Create App Policy window's General tab displays.
- From the General tab, in App Policy Name, enter a name for the policy.
- From the Apps tab, select Add. The Select Apps window displays.
- From the App Source list, select Managed Google Play.
- Select the Managed Google Play button.
- In the Managed Google Play Store, search for Microsoft Authenticator. From the results, choose the app and then Select. Microsoft Authenticator displays in the apps table.
- Select Add.
What to do next
Advanced Configuration of Microsoft Authenticator
- From the Apps table, select More.
- Select Configure. The Advanced Configurations window opens.
- From Configuration Options, select Installation Options.
- From Deployment Type, select Mandatory.
- Turn on Launch App After Installation.
- From Configuration Options, select Managed App Config.
- Turn on Enable Managed App Config.
- Turn on Shared Device Mode.
From Shared Device Mode Tenant Identifier, enter your
tenant ID.
Tip: Find your tenant ID in in the Entra Tenant ID field.
From Shared Device Mode Registration token, enter the
macro
%SHARED_DEVICE_REG_TOKEN%. - Select Save.
What to do next
Device Factory Reset
- For a device that's already registered with Microsoft Entra ID, you must factory reset it if you want to re-register with Microsoft Entra ID again.
- For a device that's already registered as Microsoft User Mode, you must factory reset it if you want to convert to Microsoft Shared Mode.
