Adding SOTI Connect Integration About this taskIntegrate SOTI Connect with your SOTI MobiControl instance. Procedure Select Global Settings from the main menu. From the Global Settings menu, select SOTI ONE > SOTI Connect to open the SOTI Connect page (see SOTI XSight). Enter a URL of the SOTI Connect server. Select Save.
