Enable Domain/Private/Public Network Firewall |
Enable to configure the type of firewall. This is the
firewall and advanced security enforcement switch. When off, no
network traffic is blocked by the server; despite any other
policy settings. |
Default Inbound Action |
Specify the default firewall action on inbound connections.
The default is the block action. |
Default Outbound Action |
Specify the default firewall action on outbound connections.
Global Ports Allow User Pref Merge |
Specify the behavior for global port firewall rules. When
off, no global port firewall rules in local store are enforced;
This setting is itemized in the Group Policy store or the
GroupPolicyRSoPStore. |
Allow Local Policy Merge |
Specify the behavior for the local policy merge. When off,
the firewall rules from local store are not applied. |
Allow Local IPsec Policy Merge |
Specify the behaviour for the local IPsec policy merge. When
off, no connection security rules from local store are enforced,
despite schema and connection security rules versions. |
Auth Apps Allow User Pref Merge |
Specify the behaviour for the application firewall rules.
When off, no authorized application firewall rules from local
store are enforced. |
Shielded |
Specify the behaviour for shielding. When on, EnableFirewall
is also on, meaning all incoming traffic is blocked from the
server regardless of other policy settings. |
Disable Inbound Notifications |
Specify the behavior for inbound notifications. When off, the
firewall can display a notification to users when an application
is blocked from listening on a port. When on, notifications are
not displayed by the firewall. |
Disable Stealth Mode |
Specify the behavior for stealth mode. When off, the server
operates in stealth mode, when on, the server disables stealth
mode in the firewall rules. |
Disable Stealth Mode IPsec Secured Packet Exemption |
Specify the behavior for stealth mode IPsec secured packet
exemption. This option is exempt if DisableStealthMode is on.
When on, and the given network traffic is secured by IPsec, and
the firewall's stealth mode rules do not prevent the host
computer from responding to unsolicited network traffic. |
Disable Unicast Responses To Multicast Broadcast |
Specify the behavior for logging successful inbound
connections. When on, the firewall logs all successful inbound
connections. Specify the behavior for unicast responses to
multicast broadcast. When on, the unicast responses to multicast
broadcast traffic are blocked. |
Log Dropped Packets |
Specify the behaviour for logging dropped packets. When on,
all dropped packets are logged by the firewall. |
Log Ignored Rules |
Specify the behavior for logging ignored rules. When on, the
server can use this value to control logging of events when a
rule is not enforced. |
