Branding the Login Page
You can select a custom logo to appear on the SOTI MobiControl login page.
To select a custom logo:
- From the Settings tree on the left, select .
				In the Login Page page that opens (see Login Page), remove the current logo (if any):
				- Click the Delete icon displayed over the current logo.
- Click Delete in the warning message that appears.
				Do one of the following:
				- Click the Browse File link in the Custom Logo field, then browse for an image file for the new logo.
- Drag an image file for the new logo and drop it into the Custom Logo field.
- Click Save.
