Email: IMAP Account
The IMAP Account email configuration enables you to configure IMAP account settings for your devices when:
Account Description
Account Name | Enter the account name of your organization. |
Reply Email Address | Enter the reply email address. |
Send Display Name | Enter the sender display name. |
User | Enter the user name associated with your email account. |
Password | Enter the account password here. |
Sync The Past | Select the amount of time email will be synced. |
Sync Interval | Select the amount of time between each sync. |
Incoming Server
Host Address | Enter the IP address or hostname, and port number, for the incoming email server.
Use SSL | This option allows the end user to select whether or not SSL is used for communication with the email server. |
Accept All Certificates | If using SSL, select this option to accept all certificates sent by the server. |
User | Enter the user name associated with your email account. Supports macros. |
Email Configuration | Enter the email address associated with your email account. Supports macros. |
Outgoing Server
Host Address | Enter the IP address or hostname, and port number, for the outgoing email server.
Alternative SMTP
Use Alternative SMTP | Specify whether to use an alternative SMTP account. This is useful when access to primary SMTP server is not available. |
Alternative User Name | Specifies the display name associated with the user's alternative SMTP email account. |
Alternative Password | Specifies the password for the user's alternative SMTP account. |
Alternative Domain | Specifies the domain name for the user's alternative SMTP account. |
