Branding the Self Service Portal Header
You can select a custom logo to appear on the Self Service Portal's header.
Note: The maximum image dimensions are 120 × 30 pixels. The maximum file size is 1 MB.
To select a custom logo:
  1. Select Global Settings from the main menu.
  2. From the Settings tree on the left, select Branding > Self Service Portal.
  3. In the Self Service Portal page that opens (see Self Service), click the Delete icon displayed over the current logo.
  4. Click Delete in the confirmation message that appears.
  5. Do one of the following:
    • Click the Browse File link in the Custom Logo field, then browse for an image file for the new logo.
    • Drag an image file for the new logo and drop it into the Custom Logo field.
  6. Click Save.
