VPN: L2TP
The L2TP VPN profile configuration enables you to configure L2TP VPN settings for devices when:
| VPN Name | The descriptive name of the VPN connection. |
| VPN Server Hostname / IP Address | The hostname or IP address of the VPN server. |
| Domain | The domain for authenticating the VPN connection. |
Authentication
| Username | The username for authenticating the VPN connection. |
| Authentication | The type of authentication used. |
| L2TP Secret | The L2TP shared secret. |
| PSKey | The pre-shared key. |
| IPSec User Certificate | The user certificate used to authenticate against the IPSec VPN server. |
| IPSec CA Certificate | The CA certificate used to verify the IPSec VPN server. |
| ID Type | The ID type. |
| ID Value | The ID value. |
