Phone Calls
Use the Phone Calls configuration to control which phone numbers a device is able to place outgoing calls to or receive incoming calls from. You perform this configuration when:
To add a new list of phone numbers to block, click Add. Existing lists will appear in the Phone Calls list where you can enable, edit, or delete them.
| Notify Server When Call is Blocked | Records all incoming and outgoing blocked calls to the server log. |
| Notify Device User When Call Blocked | Displays a message to the device user when a call from a blocked phone number is received. |
