VPN: IKEv2
Configure IKEv2 VPN settings on your devices.
Network
| Trusted Network Detection | Enable/Disable Trusted Network Detection functionality. |
Connection Settings
Authentication
| EAP Host Scheme | Select either TLS Connection or CHAP Connection. |
| Identity Certificate | Specify Client certificate for authentication. |
| Enterprise Settings | Specify trusted certificates for authentication and specify trusted server names expected from authenticated server. |
| Proxy Type | Choose between None or Manual. |
| Proxy Server | The hostname or IP address and port number of the proxy server. |
Advanced
| Applications | Use this section to exclude specific applications from the VPN. |
| Name Space | Use this section to exclude specific namespaces from the VPN |
| Network | Use this section to exclude specific networks from the VPN |
