Authentication (Phone)
An Authentication configuration enables you to set minimum requirements for password-based user authentication on a device.
Complexity Requirements
| Minimum Password Length | Select the minimum number of characters a password must have. |
| Select a Password Type | Select either a simple or complex password type. |
| Password Complexity Level | Select a password complexity level:
History
| Password Expiry | Select this option to enable password expiry. |
| Expire Password in | Enter the number of days before a password expires. |
| Unique Password Before Reuse | Select this option to set the number of unique passwords before a previous password can be reused. |
| Number of Unique Passwords Before Reuse | Enter the number of unique passwords before a previous password can be reused. |
Enforcement
On the Enforcement tab you set conditions for locking or wiping the device.
| Inactivity Before Screen Lock | The number of minutes of inactivity on the device before the screen becomes locked, forcing the user to re-enter their password to gain access.
								 A value of zero indicates that there is no limit.  |
| Failed Password Attempts | The number of incorrect attempts to unlock the device that is allowed before the device automatically resets and all data is deleted. |
