Email: POP3 Account
Account Description
| Send Display Name | Enter the display name for the email sender. |
| User | Enter the user name associated with your email account. Supports macros. |
| Sync the Past | Select the amount of time email will be synced. |
Incoming Server
| Host Address | Enter the IP address or hostname, and port number, for the incoming email server.
| Accept All SSL Certificates | If using SSL, choose whether to accept all certificates sent by server. |
| Email Configuration | Enter the email address associated with your email account. Supports macros. |
Outgoing Server
| Host Address | Enter the IP address or hostname, and port number, for the outgoing email server.
| Accept All Certificates | If using SSL, choose whether to accept all certificates sent by server. |
Alternative SMTP
